Выберете то, что вам нужно
Start with device closed, powered off, and upside down.
Locate 3 screws on the bottom plate and unscrew
Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
Once the ribbon cable has been detached, lift the keyboard away from the device.
Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
Locate the LCD ribbon cable
Pull up and away from device to detach the LCD ribbon cable.
Close and flip over laptop.
Locate the WiFi network card.
Use the plastic opening tool to pry up the two connectors.
Locate the 6 screws on the bottom and remove.
Remove the final screw in the center to release the motherboard from the case.
Еще один человек закончил это руководство.
