Введение
If your laptop is not powering on or the battery is not holding a charge, you may need to replace the battery. This guide will walk you through the steps of replacing your battery, with no tools required to complete the process.
Выберете то, что вам нужно
Slide the “Lock” switch to the right.
Slide and hold the “Release” switch to the left.
While holding the “Release” switch, lift the lip of the battery.
Lift the battery up and out of the laptop.
Еще один человек закончил это руководство.
