Введение
If your computer is only displaying a black screen, or if it is struggling to run multiple programs, you may need to replace your RAM. This guide will walk you through how to remove your RAM cards -- the same process for either card -- requiring only a PH0 screwdriver.
Выберете то, что вам нужно
Slide the “Lock” switch to the right.
Slide and hold the “Release” switch to the left.
While holding the “Release” switch, lift the lip of the battery.
Lift the battery up and out of the laptop.
Use a #0PH screwdriver to unscrew the three 4.80mm screws.
Remove the panel.
Pull the metal tabs in opposite directions, away from the RAM card.
The RAM card will swing upwards.
Еще один человек закончил это руководство.
