Введение
In order to remove the RAM safely, be sure to take out the battery first. The RAM is under a panel on the laptop and can be ejected by hand.
Выберете то, что вам нужно
Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
Apply light, outward pressure to the locks on both sides of the RAM.
Rotate the RAM up and slowly pull towards you to remove it.
In order to remove the secondary RAM, use the same outward pressure on the locks.
Lift and slide out the RAM to remove it from the slot.
