Введение
After a year of use, the battery may start to malfunction. This replacement guide will instruct you how to remove and replace the battery in your device.
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
Slide the "release" switch to the left and gently lift the battery up to remove it.
Completely remove the battery from the device.
