Sony Vaio VGN-SZ120P Hard Drive Replacement
Выберете то, что вам нужно
  1. Sony Vaio VGN-SZ120P Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 2, изображение 1 из 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Hard Drive Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 4, изображение 1 из 2 Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 4, изображение 2 из 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 5, изображение 1 из 2 Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 5, изображение 2 из 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Hard Drive Replacement, Mouse Assembly: шаг 6, изображение 1 из 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 7, изображение 1 из 2 Sony Vaio VGN-SZ120P Hard Drive Replacement: шаг 7, изображение 2 из 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio VGN-SZ120P Hard Drive Replacement, Hard Drive: шаг 8, изображение 1 из 1
    • This is where your hard drive would be located. The replacement must be a Serial ATA(SATA) hard drive
    • Remove the four hard drive securing screws.
Заключение
20 участников успешно повторили данное руководство.
Ashley Brooks
Участник с: 04/09/10
312 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 25-89, Amido Spring 2010 Участник Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 членов
Автор 63 руководств
3 Комментариев
simple and perfect in every detail
francesco - Ответить
como le cambio la pantalla a esta lap
Armand San - Ответить
como le puedo cambiar el monitor a este modelo
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 31
За всё время: 40,148
