Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the device over so that its underside is facing up. Then, slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
There are two screws on each side of the floppy drive (four screws total). Remove these screws.
Unscrew the five screws from the back of the optical drive.
Remove the two screws holding part of the floppy processing unit.
Here is an isolated image of the core hardware of the floppy drive. This is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to resolder some of the connections.
Here is an isolated image of the floppy drive casing unit.
