Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The PCG F360 comes with a floppy drive in an expansion bay. This can be replaced or swapped out for a battery or for a weight saver.
  1. Position the laptop screen-side down as shown.
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Lift the panel up and then out to gain access to the battery.
    • Lift the panel up and then out to gain access to the battery.
  3. Use the indentations to pull the old battery out.
    • Use the indentations to pull the old battery out.
  4. The battery is now removed and it is safe to move on to uninstalling other components.
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. With one hand slide and hold the tab shown. With your other hand, pull the floppy drive out of the floppy drive bay.
    • With one hand slide and hold the tab shown.
    • With your other hand, pull the floppy drive out of the floppy drive bay.
    • To replace the floppy drive, simply slide the drive into the slot until it clicks.
Заключение
ahintz
Участник с: 21.04.2010
28 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 16-3, Maness Spring 2010 Участник Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,672
