Введение
Increasing the capacity of your hard drive can improve your computer's performance.
Note: our computer did not contain a hard drive, so we just point to the hard drive bay in this guide.
Запчасти
No parts specified.
  1. Position the laptop screen-side down as shown.
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Lift the panel up and then out to gain access to the battery.
    • Lift the panel up and then out to gain access to the battery.
  3. Use the indentations to pull the old battery out.
    • Use the indentations to pull the old battery out.
  4. The battery is now removed and it is safe to move on to uninstalling other components.
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver. Slide the speaker panel towards the left, then carefully flip it over onto the keyboard. Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount. Remove the ribbon by gently pulling on it, there should be little or no resistance. Now the speaker panel can be set aside.
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Remove the metal screw that will be located at the red circle. Pull on the green strip, and the keyboard should come free easily.
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. We had a bit of a surprise when we opened our Sony. The hard drive was missing! While this is common practice when disposing of or selling a computer, it means that we're unable to show you what the hard drive looks inside the laptop. If a hard drive was present, it would attach to the motherboard by the shown connector.
    • We had a bit of a surprise when we opened our Sony. The hard drive was missing! While this is common practice when disposing of or selling a computer, it means that we're unable to show you what the hard drive looks inside the laptop.
    • If a hard drive was present, it would attach to the motherboard by the shown connector.
Заключение
ahintz
Участник с: 21.04.2010
19 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 16-3, Maness Spring 2010 Member of Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 2,521
