Введение
In order to remove the inner components, you must first remove the keyboard. The keyboard can also be replaced.
Выберете то, что вам нужно
Position the laptop screen-side down as shown.
In this position the battery housing will be located on the right hand side.
The battery is now removed and it is safe to move on to uninstalling other components.
There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
Remove the ribbon by gently pulling on it, there should be little or no resistance.
Now the speaker panel can be set aside.
Remove the metal screw that will be located at the red circle.
Pull on the green strip, and the keyboard should come free easily.
