Sony Vaio PCG-F360 RAM Replacement
Выберете то, что вам нужно
  1. Sony Vaio PCG-F360 RAM Replacement, Battery: шаг 1, изображение 1 из 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 RAM Replacement: шаг 2, изображение 1 из 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 RAM Replacement: шаг 3, изображение 1 из 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 RAM Replacement: шаг 4, изображение 1 из 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 RAM Replacement, Keyboard: шаг 5, изображение 1 из 3 Sony Vaio PCG-F360 RAM Replacement, Keyboard: шаг 5, изображение 2 из 3 Sony Vaio PCG-F360 RAM Replacement, Keyboard: шаг 5, изображение 3 из 3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 RAM Replacement: шаг 6, изображение 1 из 3 Sony Vaio PCG-F360 RAM Replacement: шаг 6, изображение 2 из 3 Sony Vaio PCG-F360 RAM Replacement: шаг 6, изображение 3 из 3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 RAM Replacement: шаг 7, изображение 1 из 2 Sony Vaio PCG-F360 RAM Replacement: шаг 7, изображение 2 из 2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 RAM Replacement, RAM: шаг 8, изображение 1 из 1
    • Slide your RAM into the housing by aligning it with the plastic, tan colored, guides until it is firmly in place.
    • The computer in the picture only has the standard 64 MB of on-board RAM. This RAM is not removable from the motherboard, but additional RAM can be added.
Заключение
ahintz
Участник с: 04/21/10
28 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 16-3, Maness Spring 2010 Участник Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 1,672
