Sony Vaio SVE111B11L Fan Replacement
Выберете то, что вам нужно
  1. Sony Vaio SVE111B11L Fan Replacement, Battery: шаг 1, изображение 1 из 2 Sony Vaio SVE111B11L Fan Replacement, Battery: шаг 1, изображение 2 из 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Fan Replacement: шаг 2, изображение 1 из 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Fan Replacement: шаг 3, изображение 1 из 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Fan Replacement, Keyboard Assembly: шаг 4, изображение 1 из 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
    Incorrect picture for this step. Is should show removing the main cover on the bottom of the laptop to reveal the memory and hard drive
    Steve - Ответить
  5. Sony Vaio SVE111B11L Fan Replacement: шаг 5, изображение 1 из 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Fan Replacement: шаг 6, изображение 1 из 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
    Not sure what wires I'm supposed to slide out. Again, picture is no help.
    Steve - Ответить
  7. Sony Vaio SVE111B11L Fan Replacement: шаг 7, изображение 1 из 3 Sony Vaio SVE111B11L Fan Replacement: шаг 7, изображение 2 из 3 Sony Vaio SVE111B11L Fan Replacement: шаг 7, изображение 3 из 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
    I found that it was easier to remove the keyboard starting from the front edge (away from the screen) because the clips are shorter on this side. The only problem is that the cable is at the front so you have more danger of breaking it. Again, the picture is incorrect - don't try to remove the panel around the keyboard as shown, just go for the central keyboard unit.
    Steve - Ответить
  8. Sony Vaio SVE111B11L Fan Replacement, Fan: шаг 8, изображение 1 из 1
    • Locate the fan and heat-sink.
  9. Sony Vaio SVE111B11L Fan Replacement: шаг 9, изображение 1 из 1
    • Locate the wires and connectors, and gently unplug them.
  10. Sony Vaio SVE111B11L Fan Replacement: шаг 10, изображение 1 из 1
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Sony Vaio SVE111B11L Fan Replacement: шаг 11, изображение 1 из 1
    • Gently lift the fan assembly up and out.
Заключение
Еще один человек закончил это руководство.
John Noll
Участник с: 09/29/16
819 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team 1-5, Crane Fall 2016 Участник Eastern Washington University, Team 1-5, Crane Fall 2016
EWU-CRANE-F16S1G5
4 членов
Автор 10 руководств
Один комментарий
There are missing steps. For example - after removing keyboard assembly, there are 4 screws under it.
Keyboard assembly is not ment to be removed in way showed in pictures. There are melted plastic tabs to keep top cover in place. By prying that, you will broke them and top cover will not be possible to put back as before.
Only keyboard itself should be removed by prying it out, starting from bottom (thoucpad). Top of keyboard has larger “ears“ and they are hooked under top cover.
Gundars Pinka - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 1,264
