Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Locate the two latches with the words “lock” and “release” on them.
Push the latches towards each other and lift the battery to remove it.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Remove the 6.7 mm screw that holds the keyboard assembly in place.
Slide the wires out, away from the solder connections.
Flip the computer over and open it.
Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
Using an opening tool, gently pull out and slightly up on the connector clip.
Gently lift the keyboard assembly up and out.
2 участников успешно повторили данное руководство.
