Sony Vaio SVE171C11L Motherboard Replacement
Выберете то, что вам нужно
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: шаг 1, изображение 2 из 2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: шаг 2, изображение 1 из 2 Sony Vaio SVE171C11L Motherboard Replacement: шаг 2, изображение 2 из 2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Locate the hard drive compartment in the upper right-hand corner.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
    • Keep the screws with their parts to make reassembly easier.
  3. Sony Vaio SVE171C11L Motherboard Replacement: шаг 3, изображение 1 из 2 Sony Vaio SVE171C11L Motherboard Replacement: шаг 3, изображение 2 из 2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached from the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove all screws holding the back panel from the laptop.
    • If you're worried about losing screws, use a piece of paper to sketch out a map. Place each screw on your map as you remove them.
    • Carefully, pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: шаг 5, изображение 1 из 3 Sony Vaio SVE171C11L Motherboard Replacement: шаг 5, изображение 2 из 3 Sony Vaio SVE171C11L Motherboard Replacement: шаг 5, изображение 3 из 3
    • Locate the blue motherboard, but do not remove it yet!
    • Remove the cables from the fan and unscrew the heatsink. The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
Заключение
Edward Briseno
Участник с: 09/26/22
893 Репутация
Автор 6 руководств
Команда
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Участник CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 135
