Введение
The battery in the Sony Vaio SVF15A16CXB laptop stores power for the laptop to use while on.
Выберете то, что вам нужно
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Using a plastic opening tool, pull the optical drive out of the computer by the seam.
Lift the clip marked in red in order to release the back cover.
Lift the back cover.
Еще один человек закончил это руководство.
