Введение
This guide helps users to remove a fan, which leads the user of the steps to remove and replace the fan of the laptop.
Выберете то, что вам нужно
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Using a plastic opening tool, pull the optical drive out of the computer by the seam.
Lift the clip marked in red in order to release the back cover.
Lift the back cover.
Unplug the clip (red black yellow wires) by pulling it in an upward direction.
Unscrew the four 4mm screws from the connecting copper piece. The two screws are located on either side of the copper piece.
