Sony Vaio SVS151190X Disk Reader Replacement
Выберете то, что вам нужно
  1. Sony Vaio SVS151190X Disk Reader Replacement, Hard Drive: шаг 1, изображение 1 из 1
    • Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
    • Slide off the back cover.
    • Ensure different sized screws are kept separate during disassembly.
  2. Sony Vaio SVS151190X Disk Reader Replacement: шаг 2, изображение 1 из 1
    • Remove the four 3mm screws using the Phillips #1 screwdriver.
  3. Sony Vaio SVS151190X Disk Reader Replacement: шаг 3, изображение 1 из 1
    • Lift out the hard drive and unplug the orange ribbon wire.
  4. Sony Vaio SVS151190X Disk Reader Replacement, Disk Reader: шаг 4, изображение 1 из 1
    • To loosen the keyboard, remove the twenty 5mm screws using the Phillips #1 screwdriver.
  5. Sony Vaio SVS151190X Disk Reader Replacement: шаг 5, изображение 1 из 1
    • Flip the device over and open it up.
    • Using a plastic opening tool and opening picks, pry off the keyboard from the bottom cover. Start from one of the corners of the device and work your way around.
    • The bottom cover is somewhat fragile, do not be too forceful when prying off the keyboard.
  6. Sony Vaio SVS151190X Disk Reader Replacement: шаг 6, изображение 1 из 2 Sony Vaio SVS151190X Disk Reader Replacement: шаг 6, изображение 2 из 2
    • The ribbon wire that attaches the keyboard and bottom cover is fragile, take care during removal.
    • Remove the keyboard from the bottom cover and place it down as demonstrated.
    • Carefully pull the plastic tab and remove the ribbon wire.
  7. Sony Vaio SVS151190X Disk Reader Replacement: шаг 7, изображение 1 из 2 Sony Vaio SVS151190X Disk Reader Replacement: шаг 7, изображение 2 из 2
    • Slightly pull up the black tape covering the disk drive's ribbon wire.
    • Pull up the blue plastic strip attached to the ribbon wire and remove the ribbon wire from the port.
    • Detach the ribbon wire from the fan so the disk reader can be removed.
  8. Sony Vaio SVS151190X Disk Reader Replacement: шаг 8, изображение 1 из 1
    • Remove the two 3mm screws using the Phillips #1 screwdriver.
  9. Sony Vaio SVS151190X Disk Reader Replacement: шаг 9, изображение 1 из 2 Sony Vaio SVS151190X Disk Reader Replacement: шаг 9, изображение 2 из 2
    • Take out the black plastic covering.
    • Remove the disk reader.
Заключение
Jacob Bellows
Участник с: 01/14/20
268 Репутация
Автор 2 руководств
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 20
За всё время: 579
