Введение
This guide will provide detailed information in regards to the internal speakers and how to replace them. This may be necessary if there is any issue with sound volume or quality from the device that isn't present when using headphones.
Выберете то, что вам нужно
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Locate and open the Micro SD slot on the top side of the device.
Remove the two screws located beneath the cover.
Attach the suction cup to the top right area of the screen.
Pull to separate the screen from the rest of the device.
Detach the display ribbon cable.
Disconnect the battery from the motherboard by pulling out the cable below the fan.
Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
Carefully remove the battery from the back assembly.
Remove the nine 3 mm Phillips #000 screws holding in the motherboard.
Disconnect the cable connected to the top of the display.
Disconnect the power jack connector on the left side of the screen.
Disconnect the daughterboard connector located above and to the right of the WiFi chip slot.
Gently pull the motherboard out by pulling from the right side of the board and flip it so that the motherboard now sits where the battery was and the underside is now visible.
Remove the speaker connector located next to the SSD slot.
You may now remove the motherboard from the device.
Remove the four 3 mm Phillips #000 screws from the upper and lower ends of each speaker module.
Once the speakers are loose, follow the wires and remove any tape holding them to the assembly.
The speaker wiring and assembly should now be completely free to remove from the tablet assembly.
Еще один человек закончил это руководство.
