Введение
Use this guide to replace the hard drive on a Sony Vaio Tap 21 all-in-one. The hard drive is covered by a circle pattern metal grill. It is located in between the battery and the motherboard.
Выберете то, что вам нужно
Locate the 13mm screws for the hard drive and use the JIS 0 screwdriver to unscrew.
Gently lift the hard drive upwards.
Ensure you have a gentle hold on the hard drive cable.
Gently pull the cable from the base where the cable header meets the hard drive.
Locate the screws.
Using the JIS 0 screwdriver, unscrew the 4mm screws.
Gently lift the frame after screws have been taken out.
2 участников успешно повторили данное руководство.
12 Комментариев
Is that a M.2 SSD Slot on the motherboard?
Nope, that’s an mPCIE/mSATA slot, not an m.2 slot. Look at the retention screw position: m.2 uses a centre screw, mPCIE/mSATA uses a corner screw.
Yes, there is an M.2 SSD slot on the left side of the motherboard. I’ve installed a 256GB SSD in the slot on my VT21
No, it’s clearly an mPCIE/mSATA slot, not m.2. The pin/notch configuration and retention screw position make it easy to identify.
You must be using a mPCIE or mSATA SSD.
Spencer Martin Navarra Chew is correct about this slot. My mistake.
