Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
How to take out the power adapter of the Sony Vaio VGN-S260
Выберете то, что вам нужно
Flip the laptop over so the Vaio logo is facing down.
Locate the battery at the top and Find the release and unlock slides on the battery.
Slide the unlock tab to the unlock position.
Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
With the tabs still in the unlock position, slide the battery away from the main case.
Flip the computer over so the Vaio logo is facedown.
Unscrew the 2 screws next to the battery.
Press down on the outer gray shell around the keyboard.
Use the spudger to gently lift keyboard.
Flip so the Vaio Logo is face down.
Locate and remove a total of 8 screws on the bottom.
Flip the laptop over so the Vaio logo is face up.
Use the spudger to pop up the upper casing.
Remove the wires that are attaching the upper casing to the motherboard.
Locate the yellow power adapter.
Follow its wire to white logic board connector.
Pull out the wire from white logic board connector.
Remove the screw next to the yellow power adapter.
Lift out power adapter and fan filter.
2 участников успешно повторили данное руководство.
