Введение
How to take out the hard drive of the Sony Vaio VGN-S260 laptop
Выберете то, что вам нужно
Flip the laptop over so the Vaio logo is facing down.
Locate the battery at the top and Find the release and unlock slides on the battery.
Slide the unlock tab to the unlock position.
Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
With the tabs still in the unlock position, slide the battery away from the main case.
Flip the computer over so the Vaio logo is facedown.
Unscrew the 2 screws next to the battery.
Press down on the outer gray shell around the keyboard.
Use the spudger to gently lift keyboard.
Flip so the Vaio Logo is face down.
Locate and remove a total of 8 screws on the bottom.
Flip the laptop over so the Vaio logo is face up.
Use the spudger to pop up the upper casing.
Remove the wires that are attaching the upper casing to the motherboard.
Find orange ribbon that is connected to the hard drive.
Find the holder of the ribbon and pop the ribbon off from it.
3 участников успешно повторили данное руководство.
