Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
How to remove the motherboard from the Sony Vaio VGN-S260 laptop.
Выберете то, что вам нужно
Flip the laptop over so the Vaio logo is facing down.
Locate the battery at the top and Find the release and unlock slides on the battery.
Slide the unlock tab to the unlock position.
Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
With the tabs still in the unlock position, slide the battery away from the main case.
Flip the computer over so the Vaio logo is facedown.
Unscrew the 2 screws next to the battery.
Press down on the outer gray shell around the keyboard.
Use the spudger to gently lift keyboard.
Flip so the Vaio Logo is face down.
Locate and remove a total of 8 screws on the bottom.
Flip the laptop over so the Vaio logo is face up.
Use the spudger to pop up the upper casing.
Remove the wires that are attaching the upper casing to the motherboard.
Locate the yellow power adapter.
Follow its wire to white logic board connector.
Pull out the wire from white logic board connector.
Remove the screw next to the yellow power adapter.
Lift out power adapter and fan filter.
Remove the screw holding the optical drive casing to the logic board.
Locate ribbon connecting optical drive case to logic board.
Pop off the ribbon.
Remove the metal PC-Card cage.
Locate brown locking tab above optical drive.
Lift up on brown locking tab until ribbon is loose.
Gently slide out and remove the optical drive from the computer.
Find orange ribbon that is connected to the hard drive.
Find the holder of the ribbon and pop the ribbon off from it.
Gently lift the motherboard from the laptop.
Remove the chip by popping the tabs on the side.
Slide out the network card.
You are now free to take the motherboard away from the base.
Еще один человек закончил это руководство.
