Введение
If you are experiencing trouble with your optical drive, you may need to use this guide in order to replace it. This is a beginner level process. There is no background knowledge or special requirements you need in order to successfully replace your optical drive.
Выберете то, что вам нужно
Remove the first of two screws located at the marker in the photo.
Grab and slide out the tray from the side of the laptop after both screws have been removed.
