Введение
In this guide, you will learn how to remove and replace the Hard Drive from your laptop. If you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the Hard Drive and you can adapt them to your own computer.
Выберете то, что вам нужно
Place your device upside down with the bottom panel facing upwards.
Orient the device so the battery is away from you as shown
Unlock the battery by sliding the lock switch to the right.
Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
Remove the two 4.8mm screws that are holding the bottom right panel cover.
Remove the Panel cover by lifting it up.
Grab the black tab that is attached to the hard drive.
Slide hard drive to the left to release it from the computer
Pull drive up from there and it will come out.
