Введение
This guide will take you through 6 simple steps to removing your circuit board. For reattachment, simply follow the steps in reverse order.
Выберете то, что вам нужно
Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
First, you must remove the black tape on the circuit board.
Next, pull up on the red and gold band until it detaches from the chip.
Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
Once the circuit board is lifted, carefully remove the chip with tweezers.
Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
For reassembling your device, follow the instructions in reverse.
