Выберете то, что вам нужно
Remove the two black 6.4mm Phillips screws from the back of the device.
Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
Remove the two 2.8 mm phillips screws located on either side of the device near the top.
Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
Lift up on and remove the Bluetooth module.
Remove the two 2.8mm silver Phillips screws on the sides of the frame.
Insert a plastic prying tool between the bottom of the case and the motherboard.
Pry up the assembly and lift it away from the case.
Remove the tape from EMF shield and the LCD housing.
Lift up on the volume control ribbon.
Remove the black shielding tape from above the Hard Drive.
Peel the foam cover away from the hard drive.
Use a plastic opening tool to remove the EMF chip from the motherboard.
Remove the plastic bracket by pushing up with your thumb to expose the display connection.
Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
Remove the mic casing by pushing up and in.
Remove the headphone jack and the bottom casing.
Lift the motherboard away from the frame with your thumb to remove it from the device.
Pull the volume control module through the space in the frame.
At this point, you will need to de-solder the existing contacts and solder the new battery in place. Please refer to iFixIt's guide on soldering. How To Solder and Desolder Connections
5 участников успешно повторили данное руководство.
3 Комментариев
i have been trying for months now so your help would be great, i have a disabled wife, who does not sllepp at night she listens to audio books on the mp3 player, we have teken out the old battery but need to buy a replacemand asap please help, series and model no is enclosed below,
NWZ-S765 5563700
Regards
Dave
Hi ich habe eine etwas leichtere Version bei der man sich die Arbeit und das Risiko ab schritt 12 sparen kann.
Ich habe alles wie hier bis zu schritt 11 gemacht.
-dann einfach die kabel vom akku auf der hälfte getrennt
-und dann den neuen akku an der stelle einfach wieder verlötet
-beide kabel mit 2 schrumpfschläuchen an den lötstellen isoliert
-und dann alles wieder zusammengebaut
Somit ist das ganze mit viel viel weniger Risiko verbunden das etwas von der Harware kaputt geht, da die ganzen Schritte ab Punkt 12 wegfallen.
