Sony Walkman WM-AF48 Film Revolver Band Replacement
Выберете то, что вам нужно
  1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Getting started: шаг 1, изображение 1 из 1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: шаг 2, изображение 1 из 3 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: шаг 2, изображение 2 из 3 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: шаг 2, изображение 3 из 3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Film Revolver Band Replacement, Replace the band: шаг 3, изображение 1 из 1
    • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
    Would be useful to see the path of the band around these parts.
    Rus Woodward - Ответить
  4. Sony Walkman WM-AF48 Film Revolver Band Replacement, Belt track: шаг 4, изображение 1 из 1
    • This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • I think you can rely on the same arrangement in other Walkman's
    I'm looking at a Sony WM-FX195 and the arrangement appears to be totally different. There's a wheel on the left (the same) but on the right there's only the motor. The right hand wheel is not present and the belt is very loose.
    jookieapc - Ответить
Заключение
8 участников успешно повторили данное руководство.
Wilson Riforgiat
Участник с: 09/11/14
924 Репутация
Автор 4 руководств
Команда
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Участник USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 членов
Автор 19 руководств
3 Комментариев
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - Ответить
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - Ответить
Helped. Wanted an idea of how to open, before breaking it!
Troyf - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 32
За последние 30 дней: 106
За всё время: 17,301
