Введение
Replace a broken outer cover on your Sony Walkman WM-AF48.
Запчасти
Детали не указаны.
  1. Remove any batteries or cassettes from the Walkman.
    • Remove any batteries or cassettes from the Walkman.
  2. Using a spudger, separate the back cover from the front. Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell. Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
Заключение
2 участников успешно повторили данное руководство.
Wilson Riforgiat
Участник с: 11.09.2014
869 Репутация
Автор 4 руководств
Команда
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Участник USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 членов
Автор 14 руководств
Один комментарий
There are four tabs on the WM-AF48 Model inside the door and around the body that are made to release the back cover.
Ethan Jones - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 1,257
