Выберете то, что вам нужно
Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
Remove cover
Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
Lift the camera from the right and simply wiggle out of the slot.
Disconnect the back camera from the port located in the upper right corner.
Lift up the camera cable using the tweezers.
Wiggle out camera from the slot.
2 участников успешно повторили данное руководство.
