  1. Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers. Insert plastic opening tool in the corner of device and slide along edges to separate adhesive Remove cover
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
    • Remove cover
  2. Locate the SD card reader in the bottom left hand corner
    • Locate the SD card reader in the bottom left hand corner
    • Remove all screws connecting the metal plate to the device.
  3. After all the screws have been removed lift the circuit board up to wiggle free.
    • After all the screws have been removed lift the circuit board up to wiggle free.
  4. After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
    • After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
    • Once placed there lift up and disconnect the SD card reader from the device.
Заключение
Martin Luna
Участник с: 24.09.2014
1 654 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 15-6, Remmell Fall 2014 Member of USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 членов
Автор 5 руководств
Один комментарий
How long did it take to complete???
Steve Donnelly - Ответить
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
За всё время: 1,678
