Введение
If the LCD display of your phone is broken, in this manual we will show you, how to disassemble the phone and how to change it.
Выберете то, что вам нужно
Видео обзор
The small bottom bezel is held by 2x locking clips.
Preferably use plastic tools for disassembling.
There are 4x silver screws and 3x black screws.
The rear cover is held by 5x locking clips.
Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
Remove the back cover.
With a plastic tool disconnect one by one:
LCD Display flex cable
Touchscreen flex cable
Menu Buttons Board flex cable
Coaxial Wire Antenna cable
Disconnect the other side of the flex cable and remove the Home Buttons board.
Unstick the camera button.
The touch screen is stuck to the frame with double side adhesive tape.
By using plastic tools gently start separating.
At the bottom is glued on firmly because the bonded surface is larger.
Use a hot air to make separating more easy and safety.
With a plastic tool, carefully separate the LCD display from the touch screen.
Clear the LCD Display from the old adhesive tape.
Install the new LCD into the frame and put adhesive tape. Be careful not to cover the holes (for the speaker, menu buttons etc.).
Install the Touchscreen.
Did you do it successfully?
2 участников успешно повторили данное руководство.
