Введение
How to replace broken Digitizer Glass on Sony XPERIA E.
Выберете то, что вам нужно
Видео обзор
The small bottom bezel is held by 2x locking clips.
Preferably use plastic tools for disassembling.
There are 4x silver screws and 3x black screws.
The rear cover is held by 5x locking clips.
Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
Remove the back cover.
With a plastic tool disconnect one by one:
LCD Display flex cable
Touchscreen flex cable
Menu Buttons Board flex cable
Coaxial Wire Antenna cable
Disconnect the other side of the flex cable and remove the Home Buttons board.
Unstick the camera button.
The touch screen is stuck to the frame with double side adhesive tape.
By using plastic tools gently start separating.
At the bottom is glued on firmly because the bonded surface is larger.
Use a hot air to make separating more easy and safety.
Did you do it successfully?
Еще один человек закончил это руководство.
2 Комментариев
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Jo PCB main hota hai
