Введение
Sony Xperia E1, Dual, D2004, D2005, D2105 - how to disassemble the phone and change the Digitizer, LCD Display, Loudspeaker, etc.
___________________________ Video tutorial: ___________________________
Выберете то, что вам нужно
Видео обзор
Turn off the phone, remove the battery, SIM card and micro SD card.
The screws are Torx T4. One of them, near the microSD card reader is different.
Touch screen flex cable. Disconnect it.
LCD Display flex cable. Open the connector.
The logic board is held to the display frame by several plastic locking clips. Use a plastic tool to remove it.
If the glass is broken, put some scotch tape to prevent it from breaking to pieces.
Use a hot air to soften the adhesive tape.
Start with separating at the middle, where the contact area is smaller.
Clean the frame.
Put adhesive tape if the new spare part doesn't have any.
Install the new Digitizer.
Use again hot air and some pressure to stick the glass better.
Start wit reassembling.
2 участников успешно повторили данное руководство.
2 Комментариев
Hi I have a problem with wifi it's a hardware issue as I dropped it yesterday since from then the issue started please help me to fix it
