Введение
Sony Xperia E3 - How to disassemble the device and replace the battery.
D2202, D2203, D2206, D2243, D2202
Выберете то, что вам нужно
Видео обзор
Turn off the device
Remove the SIM and the memory cards.
Remove 4x rubber corners.
There are 6x black screws Torx T4, remove them.
Disconnect the battery flex cable.
Use a Hair dryer and warm little the battery.
Use the white tape on the battery to separate it from the main frame.
Battery:
Li-ion, 2330 mAh
model: LIS1551ERPC
The same battery is for Xperia M2 and Xperia M2 Aqua.
4 участников успешно повторили данное руководство.
2 Комментариев
Hello
How many times I must use Hair dryer please ?
çà serait beaucoup en langue française
