Введение
Sony Xperia E3 - How to disassemble the device and to change the Glass digitizer.
D2202, D2203, D2206, D2243, D2202
Выберете то, что вам нужно
Видео обзор
Turn off the device
Remove the SIM and the memory cards.
Remove 4x rubber corners.
There are 6x black screws Torx T4, remove them.
Disconnect the touch screen flex cable.
Disconnect the battery flex cable.
With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes.
Use a thin plastic tool, like a plastic pick and start the separation from the underside.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Now continue with a plastic card.
Remove the touch screen.
Now is time to test the phone.
With a plastic pick gently scrape the glue.
With a cloth and isopropyl alcohol clean the LCD.
On the new touch screen or on the main frame put adhesive sticker 3mm.
Lift the logic board a little bit, so that the touch screen flex cable can pass.
6 участников успешно повторили данное руководство.
