Введение
E2104, E2105, E2115, E2124
How to disassemble the device and remove / replace the battery or the loudspeaker.
Выберете то, что вам нужно
Видео обзор
Remove the back cover and any installed SIM and memory cards.
There are 8x black screws Torx T4. Remove them.
Remove the small black rubber at the lower left corner.
Under it is the battery flex cable, disconnect it.
Use a plastic tool to separate the middle frame.
The battery is glued to the middle frame with an adhesive tape.
Loudspeaker
5 участников успешно повторили данное руководство.
