Введение
This guide will take you step by step through the process of replacing your Sony Xperia L2 rear camera. This guide will help with an inoperable or faulty rear camera to provide a fully operable rear camera.
Выберете то, что вам нужно
Use the plastic opening tool to pry the back case of the phone off.
Disconnect the fingerprint sensor.
Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
Disconnect the battery cable from the motherboard.
Pry up the battery and remove it from the device.
Detach the rear camera from motherboard and remove it from the device.
