Введение
This guide will take you step by step through the process of replacing your Sony Xperia L2 screen. This guide will help those who have a broken or unresponsive screen to extend the life of your phone.
Запчасти
Никакие детали не требуются.
  1. Before disassembling the battery, power off your Sony Xperia L2 LTE. Remove SIM card tray.
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Use the plastic opening tool to pry the back case of the phone off. The fingerprint sensor is connected to the motherboard. Disconnect the fingerprint sensor.
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Disconnect the battery cable from the motherboard. Pry up the battery and remove it from the device.
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
  6. Unclip circuit connectors from phone to motherboard.
    • Unclip circuit connectors from phone to motherboard.
  7. Use blue plastic opening tool to pry off the motherboard. Use blue plastic opening tool to pry off the motherboard. Use blue plastic opening tool to pry off the motherboard.
    • Use blue plastic opening tool to pry off the motherboard.
  8. Microwave the iOpener for 30 seconds. Place the iOpener on the phone screen for 90 seconds to loosen the adhesive.
    • Microwave the iOpener for 30 seconds.
    • Place the iOpener on the phone screen for 90 seconds to loosen the adhesive.
    • Use the suction tool and a pick to remove the screen from the phone.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  9. Unhook the screen sensor from the phone to detach the screen from the device.
    • Unhook the screen sensor from the phone to detach the screen from the device.
Заключение
Carrie Schmitt
Участник с: 10.09.2018
199 Репутация
Автор 2 руководств
Команда
University of Alabama, Team S2-G6, Bedsole Fall 2018 Member of University of Alabama, Team S2-G6, Bedsole Fall 2018
UA-BEDSOLE-F18S2G6
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 12
За всё время: 97
