Введение
For this model ,removing the Logic board is very difficult operation!!!! If you do something wrong, you may damage the board.
Please SUBSCRIBE to my channel ツ
Видео обзор
  1. Warm the Back Cover. You can use a hairdryer. Be careful, the Cover is plastic. Use a small suction cup and plastic tools for separating the Rear panel.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
  2. Disconnect the Battery Cable. The battery is stuck to the phone fame. Use the white tape to remove it. Li-Polymer Battery, 2230 mAh
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
  3. Remove the SIM and the memory cards. Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
    • Remove the SIM and the memory cards.
    • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
  4. Disconnect one by one:
    • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
  5. Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector. Put one plastic spudger between the Logic board and the Main frame.
    • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
    • Put one plastic spudger between the Logic board and the Main frame.
  6. Step one: move aside less the left side of the board - down. Step two: the left side of the Logic board must go out of the main frame. For this manipulation use only plastic tools.
    • Step one: move aside less the left side of the board - down.
    • Step two: the left side of the Logic board must go out of the main frame.
    • For this manipulation use only plastic tools.
Заключение
16 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
179 934 Репутация
Автор 324 руководств
Команда
Master Techs Участник Master Techs
Community
300 членов
Автор 1 006 руководств
Комментариев: 2
My mobile charge bin problem how to find that problem , no charged my mobile…
jeeva jeeva - Ответить
Removing the motherboard is unnecessarily difficult on this model! Why make it like this? One would figure the screws would do a good enough job of securing it to the frame. I guess having to wiggle it out is just part of the fun, right?
Also, getting parts for this model (and it’s water-resistant twin) sucks. I’m currently in the market for a display+touch assembly and it seems I’ll have to resort to importing from AliExpress.
Luis Alejandro Araúz - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 14,015
