Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
With this guide we will help you if you have a problem with the Loudspeaker and you want to disassemble the phone and change it.
Выберете то, что вам нужно
Видео обзор
Warm the Back Cover. You can use a hairdryer.
Use a small suction cup and plastic tools for separating the Rear panel.
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
Disconnect the Battery Cable.
The battery is stuck to the phone fame. Use the white tape to remove it.
Li-Polymer Battery, 2230 mAh
Part number: LIS1551ERPC
Remove the two T5 screws.
Use a plastic tool to unstuck the the Loudspeaker module from the Main frame.
5 участников успешно повторили данное руководство.
Один комментарий
For anyone doing this on an Xperia M2 Aqua: BE VERY CAREFUL! There’s strong adhesive foam around the microphone (which points forwards and sits under the screen on the Aqua, unlike the regular M2 where it points downwards). Try your best to detach the loudspeaker module from the mic/vibra/antenna PCB first, then very, VERY carefully pry under the PCB with a plastic tool in order to release the adhesive. If you try to remove the whole assembly by lifting from a corner and pulling it sideways, you WILL break the main microphone. Why they’d put such a delicate component in an accident-prone spot is beyond me. Don’t get me wrong, it’s not an expensive fix, but the inconvenience will get on your nerves haha.
