Введение
This guide can be used to replace the headphone jack.
Запчасти
Никакие детали не требуются.
  1. Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  5. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  6. Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
    • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
  7. Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
    • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
Заключение
4 участников успешно повторили данное руководство.
Christina Wojaczyk
Участник с: 26.09.2014
1 425 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 13-3, Staggers Fall 2014 Member of USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 9
За всё время: 4,702
