Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: шаг 2, изображение 1 из 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing the internal cover: шаг 3, изображение 1 из 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: шаг 4, изображение 1 из 2 Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: шаг 4, изображение 2 из 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing Chip: шаг 5, изображение 1 из 1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: шаг 6, изображение 1 из 1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Remove back facing camera: шаг 7, изображение 1 из 1
    • Then using the tweezer, carefully remove the back facing camera component.
Заключение
5 участников успешно повторили данное руководство.
Christina Wojaczyk
Участник с: 09/26/14
1 450 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 13-3, Staggers Fall 2014 Участник USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 членов
Автор 7 руководств
2 Комментариев
Hlo hi sir Sony back cam of Sony Xperia t2 ultra
sai kiran - Ответить
Hi, Sir T2 Ultra dual Camera shows error - Unfortunately, Camera has stopped working. pls help . Thank yo
Alan Mathew - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4,115
