Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Removing this part is hard for the first time because the manufacturer used adhesive to keep it in place.
Запчасти
Детали не указаны.
  1. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  5. Use the plastic opening tool to detach the ribbon running across the battery. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Заключение
4 участников успешно повторили данное руководство.
Adam Giniger
Участник с: 22.09.2014
1 283 Репутация
Автор 8 руководств
Команда
USF Tampa, Team 4-4, Brown Fall 2014 Участник USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 членов
Автор 10 руководств
Один комментарий
Is it necessary to back up the phone before replacing the battery, or will the settings be preserved?
r3woods - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,882
