Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use the plastic opening tool to pry the top plastic section off.
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to remove the loud speaker module.
Use the plastic opening tool to detach the ribbon running across the battery.
Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Unhook the 2 connections between the harness and phone shell.
Using the plastic opening tool, pry the harness up and remove it.
The final step is taking the entire harness off of the phone.
Use the Phillips #00 to remove the 3 5mm screws.
Lift the plastic cover off.
Use the plastic opening tool to pry the motherboard out of the phone shell.
Use the plastic opening tool to detach the ear piece speaker.
Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
Еще один человек закончил это руководство.
