Введение
If your phone's battery is not working or not charging, follow these steps to help guide you through the process or removing and replacing the battery
Запчасти
Детали не указаны.
  1. Set the phone screen down on a clean flat, surface.
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Insert the plastic opening tool in between the battery and the phone body.
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
Заключение
2 участников успешно повторили данное руководство.
Faisal
Участник с: 07.10.2014
208 Репутация
1 руководство автора
Команда
USF Tampa, Team 7-2, Leahy Fall 2014 Участник USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,177
