Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If your phone's earphone jack is not working properly, follow these steps to assist you in replacing the headphone jack.
Запчасти
Детали не указаны.
  1. Set the phone screen down on a clean flat, surface.
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Insert the plastic opening tool in between the battery and the phone body.
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  5. Remove the six size 0 Phillips screws.
    • Remove the six size 0 Phillips screws.
  6. Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  7. Locate the earphone jack on the top left of the black plastic back cover.
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
Заключение
2 участников успешно повторили данное руководство.
Bader
Участник с: 07.10.2014
545 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 7-2, Leahy Fall 2014 Участник USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 996
