Введение
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Выберете то, что вам нужно
Stick the small suction cup on the bottom half of the back surface of the phone.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Apply heat to the copper RAF antenna.
Where can i buy this copper raf antenna
I also need it for my phone I kinda ripped it apart oops ?
Tiybah -
Mike J - I found that simply raising the edge overlapping the battery connector gave sufficient room to disconnect the battery so no need to remove the antenna and risk tearing!
Peel back the RAF antenna.
Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
11 участников успешно повторили данное руководство.
Один комментарий
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
