Sony Xperia XA Battery Replacement
Выберете то, что вам нужно
  1. Sony Xperia XA Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: шаг 2, изображение 1 из 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: шаг 3, изображение 1 из 3 Sony Xperia XA Battery Replacement: шаг 3, изображение 2 из 3 Sony Xperia XA Battery Replacement: шаг 3, изображение 3 из 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: шаг 4, изображение 1 из 3 Sony Xperia XA Battery Replacement: шаг 4, изображение 2 из 3 Sony Xperia XA Battery Replacement: шаг 4, изображение 3 из 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: шаг 5, изображение 1 из 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
    Where can i buy this copper raf antenna
    mhel nival - Ответить
    I also need it for my phone I kinda ripped it apart oops ?
    Tiybah -
    Mike J - I found that simply raising the edge overlapping the battery connector gave sufficient room to disconnect the battery so no need to remove the antenna and risk tearing!
    Mike Jurkiewicz - Ответить
  6. Sony Xperia XA Battery Replacement: шаг 6, изображение 1 из 1
    • Peel back the RAF antenna.
    I’ve ripped the copper part of this would I be able to get a new part or will the phone not work with out it?
    Tiybah - Ответить
  7. Sony Xperia XA Battery Replacement, Battery: шаг 7, изображение 1 из 3 Sony Xperia XA Battery Replacement, Battery: шаг 7, изображение 2 из 3 Sony Xperia XA Battery Replacement, Battery: шаг 7, изображение 3 из 3
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: шаг 8, изображение 1 из 2 Sony Xperia XA Battery Replacement: шаг 8, изображение 2 из 2
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: шаг 9, изображение 1 из 1
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: шаг 10, изображение 1 из 1
    • Lift the battery out with your hands.
Заключение
11 участников успешно повторили данное руководство.
Cassidy Davis
Участник с: 04/18/18
621 Репутация
1 руководство автора
Команда
Cal Poly, Team S17-G2, Livingston Spring 2018 Участник Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 членов
Автор 8 руководств
Один комментарий
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 40
За всё время: 5,276
