Введение
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Выберете то, что вам нужно
Stick the small suction cup on the bottom half of the back surface of the phone.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
Push back the two retaining tabs on the top of the loudspeaker with the spudger.
With a spudger, pry up the orange connector that is directly underneath where the loud speaker was just removed.
Pry up the small silver connector on the right side of the bottom of the phone with a spudger.
Remove the two 4 mm screws with a Phillips #000 screwdriver from the left side of the back of the screen.
Remove the three 3mm screws with a T5 screwdriver along the side of the device where the volume buttons are.
Pull up the orange and black tab that is on the left half of the middle of the screen.
Remove the three 3 mm screws with a Star Bit T5 Screwdriver on the opposite side of the phone.
6 участников успешно повторили данное руководство.
