Введение
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Выберете то, что вам нужно
Stick the small suction cup on the bottom half of the back surface of the phone.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
Push back the two retaining tabs on the top of the loudspeaker with the spudger.
2 участников успешно повторили данное руководство.
